Hi all,
I need a help in one of my project.
I want to connect two battery banks each of capacity 240V, 1000Ah in parallel and want use as master n slave operation and system always connected to inverter to run the load. Now I am having a doubt that if master battery bank is discharged totally then I need to connect slave Battery bank. I want to connect the slave battery bank which is charged in parallel and then disconnect the master battery bank which is discharged.
Is it the right way to operate?? What will be the standard practice and Problems with DC braking??
Thanks Guys.
Santosh
Thanks Guys.
Santosh
