I read the question as the lamps were in parallel making it a 2 ampere load or 4.25 ohms.With a 8.5VDC battery hooked to 2 parallel groups of 5 lamps drawing .2 AMPS each what is the total load being applied?
Each lamp in each string needs 0.2A. That means each string needs 0.2A too, am I wrong here?JoeJester said:I read the question as the lamps were in parallel making it a 2 ampere load or 4.25 ohms.
Should we take the problem too seriously and try to match the problem to the reality? I suggest we stick to the initial statement in the first post and solve it theoretically.328 lamp
Voltage: 6V, 6 Volts
Amperage: .2A, 200mA
6 cell ni-cad = 7.2 V
If you wire five lamps in series, each string would require 30 volts to operate properly at the 0.2 Ampere standard. Your nicad is a six cell battery.
The problem calls for each string of five to be wired parallel for proper operation. Kirchoff's current law will give you the total amperes in the load.
Minimum battery rating ... ampere hour / 4 or ampere hour * 0.25
No we shouldn't. It did however require clarification which was provided by the OP. At that point, the proper guidance should have been provided illustrating where the OP understands that incomplete questions will get varying responses as the members will try to interpet what was asked.Should we take the problem too seriously and try to match the problem to the reality?
by Aaron Carman
by Jeff Child
by Aaron Carman
