Parallel Circuit
Discussion in 'The Projects Forum' started by Lightfire, Apr 6, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I made this one circuit but cannot figure out or identify what circuit is the one I made. But I am about 90% sure that it is a parallel circuit. I guess.
    See my schematic attached below.
  2. HallMark
    Member
    Apr 3, 2011
    89
    5
    yes the connection is Parallel.
    Lightfire likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it is a Parallel circuit.
    Just a couple of notes about drawing schematics in a standard way;
    1) More positive voltages towards the top, more negative voltages on the bottom.
    2) Inputs come from the left, outputs go towards the right.
    So, your battery should be turned so that the positive terminal is on top, and moved over to the left side.
    If you draw schematics in a standard format like that, it makes them easier to understand.
    Some types of circuits make more sense if they are drawn in a "mirrored" fashion, such as an H-bridge or a flip-flop made out of discrete transistors, resistors and capacitors - but they are exceptions to the standard rules.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That is correct. You have a parallel circuit. A series circuit would look something like this, taking into account what SgtWookie suggested:
    Der Strom
  5. Lightfire
    Oct 5, 2010
    690
    21
    Yep. I just made my mine there's one in left, and there's one at right because my design in actual is like that. :)
    P.S. @ somebody, how can you make your whole schematic colored black??? :)
  6. wayneh
    Sep 9, 2010
    12,382
    3,241
    Your circuit doesn't really have an input or output, just a power source and a load. I'm not sure where exactly you draw a line in defining these terms, but I'd say that an input or output usually carries information, such as an audio or video signal, and not just power. An exception is a power adapter, where the input is one form of power from a source and the output is another.
