I have a camera that uses a 9-volt battery, or has an AC adapter if I want to plug it in. The battery life is approximately 1.5 hours per 9-volt.
If I connect three or four 9-volt batteries in parallel, so as not to increase voltage output, would I theoretically achieve three or four times the battery life? I would like to get approximately 8 hours of run time...
Would the amperage be changed by a parallel connection? I do not want to burn up my camera!
Thanks in advance for any answers!
