I am currently working on my own project which the power source is only a battery. Anyway, here we go.
I made a parallel circuit.
Bulb-2 (which is both 12.0 volts)
Battery (12.0 volts) (wet cell) I admit that its battery of vehicle...
Then when I turn off (or remove) the other one bulb, the other one bulb is going brightly, and when I turn on (or put) the other one bulb, the other one bulb is going looks like not bright anymore...
Is there any way to make it balance which both bulb is going brightly. I mean if I put a one other bulb, the other bulb will not be affected...
Thanks! Sorry for my bad English and bad Explanation!!! Hope you understand!
