Hi everyone,
Can anyone tell me the formula to be used in order to measure PANEL VOLTAGE "P_V" across R28.
The schematic can be found in the attachment.
We have two ground here :
1st is PANEL Ground indicated by P- and 2nd is system ground which is marked as a general GND symbol.
Here Panel Gnd and system ground is separated by a MOSFET which is not shown in the schematic. However to measure Panel voltage there is NO requirement of MOSFET.
Basically i want to know as what conversion factor i should use to convert ADC reading to actual panel voltage (ADC is of 10 bit) which is NOT possible without the actual calculation.
Normally we use a resistor divider configuration for voltage measurement which is quite simple BUT what in case if BJT (PNP) is inserted in between.
Thank you
Thank you
