Panel Socket And Plug Banging Head Off Wall
Discussion in 'The Projects Forum' started by bowlingo, Feb 11, 2012.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I have been having a hell of a performance trying to find suitable panel sockets and plugs. It has involved spending several hours on the phone to RS, Farnell, Digikey, mouser etc. I have sent 2 x sets back to RS and received a set from Farnell (D-subs) today of which the cable entry holes are not big enough and the solder buckets are not big enough to take the 0.75mm wires.
    Here is what I am after
    1) 3A max load, 27-40 way plug and panel socket capable of taking 15.8mm outer diameter 24 core YY cable with 0.75mm csa wires
    2) 3A max load, 11-15 way plug and panel socket capable of taking 10.5mm outer diameter 12 core YY cable with 0.75mm csa wires
    They have to be screw or solder bucket connections
    They can be round, square, rectangular etc
    They can be any colour
    They can be push, push twist, latch etc type connections
    Today I recieved these D-sub connectors
    http://uk.farnell.com/mh-connectors/dtzk-37-k/backshell-d-diecast-37way/dp/463048?Ntt=463048
    During the week I have received 2 sets that didnt match my requirments
    The only option available to me is aparently these
    http://uk.farnell.com/epic/10-1360-...t-hbe-side-entry-32way/dp/9903216?Ntt=9903216
    http://uk.farnell.com/epic/10-1320-...t-hbe-panel-base-32way/dp/9903291?Ntt=9903291
    http://uk.farnell.com/epic/10-0820-...lete-connector-kit-hbe/dp/9904433?Ntt=9904433
    These are very big and are 16A rated (hence the size), the big one is 90mm long x 95mm high and 80mm thick...they are also rediculously expensive
    Anyone any ideas?
  2. bowlingo
    Jun 29, 2011
    162
    Any ideas?...sorry to be impatient
  3. Paul Kerry
    Member
    Jan 9, 2012
    36
