panel mount pins and breadboards
Discussion in 'The Projects Forum' started by hunterage2000, Jun 29, 2012.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    Can someone have a look at the attached image and tell me what kind of pins these are and what component do I need to attach it to my breadboard?
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    *solder lugs* just solder some wires on and you are good to go.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    The round holes are made to accept stranded hook up wire but you can use solid 22 AWG wire like you use for breadboard jumpers. The spacing of the solder lugs is not correct for your board so solid pins would not work well without bending the lugs into position.
    Many of us use top adjusting multiturn trim pots on breadboards since they take up less space and fit without adaptation but they're more difficult to adjust.
