hello guys,
can one use a DPST panel mount type switch on a PCB?! i need a DPST switch to switch ON/OFF two 12Vdc batteries(5Ahr each). i need it from farnell and it has to be cheap (my professor wants me to use cheap components) . the only cheap ones i found that could withstand this current and voltage were panel mount type, therefore the question>
thank you
thank you
