panel meter Volts vs mV
Discussion in 'General Electronics Chat' started by Gregfox, Mar 17, 2013.
  1. Gregfox
    Jul 23, 2011
    14
    I have a panel meter that reads in volts, from 00.01 up to 30 volts.
    I also have a circuit I want to connect it to, that puts out 0-199 mV.
    When I connect to the circuit and try to read say, 140mV, my meter reads 00.01.
    Is there any way (other the easy way out, of simply getting a meter that reads in mV) for me to be able to read the 140 mV more precisely?
    I thought of an H bridge or something along those lines, but ahhh, the must be an easier way.
    Any thoughts appreciated.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    You can go down in sensitivity, i.e. read higher voltages, but you cannot go the other way.
    If it is an analog meter you can try to find the series resistor and change its effective value by either replacing it or bridging it with another resistor.
    Gregfox likes this.
  3. Gregfox
    Jul 23, 2011
    14
    Thanks, I knew you would say that.
