Painting PCBs before silk screen application using toner transfer method?
Discussion in 'General Electronics Chat' started by spinnaker, Dec 23, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,099
    1,190
    Does anyone paint their PCBs before applying the silkscreen using toner transfer method?
    If so what do you use? I assume you would need a high temp paint like engine paint?
    I was thinking of painting while to make the silkscreen more readable with the black toner.
    I sure wish you could get white toner in the stores.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is one of my many pending experiments. I don't know if the clear acrylic Krylon will dissolve toner or not, I will let you know. Of course, I am talking about doing after the transfer, it sounds like you want to do it before.
    If it works let us know.
  3. EB255GTX
    Apr 30, 2011
    54
    I do - standard acrylic spraycans seem to be fine, but high temp would only be better of course.
    I tried enamel spraycans of a few colors a while ago (see attached) but as i normally use a glass paint on the copper side as a solder resist, i also tried using that on the non solder side as well since it is high temp, water based, cheap, and comes in a variety of colours (including white but i just use green for both sides). It works well but for single sided boards, toner straight on the fibreglass is quite high contrast (see pix)
    Cheers
    EB
