I working on a 12v project with the P7 LED (3.6v-4.2v, 2800mA). Is there a prebuilt driver out there that will power this LED off of a 12v battery?
I was planning on using the appropriate resistors to get the voltage where it needs to be, but because other things will be running off of the same battery I am concerned that the voltage variance will damage the LED. So will a driver regulate the output even if the input shifts?
Thanks for helping this newbie, it is much appreciated.
