P-N junction
Discussion in 'Homework Help' started by Hello, Dec 20, 2008.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    A certain P-N junction diode of germanium has a leakage current of 10^-8 A at 127 Deg C. The diode is forward-biased with a constant-current source of 1 mA at room temperature. If current is assumed to remain constant calculate the junction barrier voltage at 127 Deg C.
    - There is the room temperature and 127 Deg C. Not sure if u have to use the room temperature as well somehow?!
    P.S. This was posted in a previous thread but wasn't resolved, hope someone else can have a go.
  2. mik3
    Feb 4, 2008
    Use the diode equation and rearrange it to find V. Use 127 degrees Celcious to define KT (note that you have to convert celcious to kelvin).
