P channel MOSFET Wiring not working
Discussion in 'General Electronics Chat' started by teeveeloon, May 29, 2016.
  1. teeveeloon
    May 29, 2016
    Essentially I've got a P channel MOSFET that I'm trying to connect.
    The voltage of the battery is 4.2ishV (18650)
    I have attached my sketch of the circuit
    I want the voltage at "D" to be zero when the switch is off and full voltage when it is on.
    At the moment, it reads 4.2 with the switch on and anything between 0-4.2V when it is off. How do i get it to be zero the whole time when the switch is off??
    Many many thanks, I've tried so hard to figure this out.
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,573
    523
    Connect 10k resistor from source to gate.
    You can really use anything between about 1k and about 100k, but 100k might make it turn off too slow so 10k is good.
    A mosfet has an internal capacitance that stays charged when the gate is open, so a resistor is required to drain that capacitance to let the mosfet turn off.
    Also, a small series resistor in the gate might be a good idea too, like 50 ohms. That is to limit gate current when turning on. Min about 10 ohms, max about 100 ohms.
  3. JMac3108
    Aug 16, 2010
    349
    66
    TeeVeeloon,
    I had a little trouble figuring out your circuit diagram at first, so I re-drew it in a more standard schematic form. One problem you have is that you've connected your positive supply (4.2V) to the drain of the PFET. Are you aware that FETs have an intrinsic diode? This is an internal diode that is part of the physical construction of the FET, and in the case of the PFET it points from drain to source which is not what you want for your circuit. You need to turn the PFET around. See the attached drawing of your original circuit, with the intrinsic diode shown, and my suggested changes. Also, MrAl is right, you need a resistor from the gate to source. Always use a gate-source resistor on your FETs to ensure they stay off. Good luck with your circuit!
  4. dl324
    Mar 30, 2015
    3,397
    653
    Check the diagram again. The device is connected connected correctly; it's just missing the resistor between gate and source.
  5. ScottWang
    Aug 23, 2012
    4,936
    777
  6. dl324
    Mar 30, 2015
    3,397
    653
    Welcome to AAC!
    As mentioned by the earlier posters, you need a resistor between gate and source.
    It would be helpful if you included part number(s) and drew schematics in a more conventional way.
    Note that the dashed line for an enhancement mode device is often drawn as a solid line when hand drawing. That can be confused with a depletion mode MOSFET which is on with no gate bias, but they're seldom used.
  7. teeveeloon
    May 29, 2016
    Thanks so so much guys, put a 10K on and it works great!
    Just to iron out the other problems now
    Cheers
  8. JMac3108
    Aug 16, 2010
    349
    66
    As other said, you might want to try to draw the schematics in a more conventional way. I still can't figure out what you drew :)
    I thought the rectangle was a resistor tied to the source, and the half circle with a D in it was the battery tied to the drain!
  9. teeveeloon
    May 29, 2016
    What software do you guys use to create the schematics?
  10. dl324
    Mar 30, 2015
    3,397
    653
    I used the free version of Eagle.
