P Channel Mosfet (switching leds).
Discussion in 'General Electronics Chat' started by PVBLLLC, Feb 6, 2016.
  1. PVBLLLC
    Feb 6, 2016
    Can some one tell me what's wrong with the attached sketch?
    The p-channel fet/12vLED's won't turn off with the potentiometer.
    I'm using a p-channel fet because the LED array I'm using has 5 segments with a common ground.
    The arduino (bar graph sketch) and potentiometer work correctly with 9 volt LED's.
    Please ref attached.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You just hyjacked an older existing thread:
    P Channel Mosfet
    Now you have a thread of your own.
    Bertus
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Where do you think the gate of the fet will get its drive?
    Please post a propper schematic with the schematic symbols in stead of a drawing of the setup.
    Bertus
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    652
    Welcome to AAC!
    You have the MOSFET connected wrong and probably don't need a transistor to drive the gate.
    I don't see a pot in your drawing.
    A "proper" schematic would make it easier to read your circuit. When you post pictures or schematics, please make sure they can be read. I had to use a photo editor to magnify your picture to read the text.
  5. PVBLLLC
    Feb 6, 2016
    Thanks for the help guys!!!!
    I'm not an electrical engineer, designer, etc.
    Have combined other works to get where I am with this project.
    I don't know how to generate a proper sketch and this is my first post.
    Can you edit my set up sketch showing the proper connections for the MOSFET?
  6. PVBLLLC
    Feb 6, 2016
    please ref attached bargraph-arduino-demo
  7. dl324
    Mar 30, 2015
    3,379
    652
    That doesn't mean you shouldn't learn how to draw a "proper" schematic so that you can communicate in the language that EE's understand.
    This is how I interpreted your "schematic"; I added the ground connection between the battery and the rest of the circuit.
    This would never work. You have the MOSFET connected backwards and the LED would always be on. If the MOSFET were connected correctly, it would not turn off properly because there's no pull-up on the gate.
    This is how it should be drawn:
