I was implementing a circuit to only turn on a voltage to a sensor ("Measure Pin") when there was VCC (3.3V) on my board. (Vin may be there even when VCC is not). I have attached my circuit here. Basically, Vin should go through to "A" and further down the voltage divider only when there is VCC (DVCC3P3 in my schematic).
However, I would like to have Vin be in the range of 6V-36V. From the NTR0202 spec, it seems that the gate-source voltage should only be a maximum of 20V. So I think if Vin is greater than 20V I'll have an issue, correct? Are there any recommendations for the replacement of this P-channel MOSFET?
I found the ZVP4525GTA, with Gate-Source of +/-40V, but with a Drain-source of -285V is this overkill?
Any other comments would be appreciated. Thank you very much.
