P.A.D.D.
Discussion in 'Off-Topic' started by JingleJoe, Aug 18, 2011.
  1. JingleJoe
    Jul 23, 2011
    185
    10
    I suffer from Attention Deficit Disorder ... Project ADD, I just can't keep my mind on one project! As soon as I start one I'm already thinking about another!
    Then by the time the first one is half way done I am already bored with it because it's kind of working already so I start something new and the first one is never finished and the cycle just repeats over and over untill my workbench is piled high with half built robots and machines (like it is right now) :(
    Does anyone else suffer from this problem? If so, have you found a cure!?
  2. shortbus
    Sep 30, 2009
    4,086
    1,665
    No cure that I know of. I do the same thing. I've got 5-10 projects going at any one time. Get stuck on one and go to another:) Hope to finish a couple before I die.
    If you come up with a cure please post it here.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Rotation is the key my friends. Come back to it, a few do get done. I have the same problem.
  4. JingleJoe
    Jul 23, 2011
    185
    10
    Rotation! Yes!
    That might just work, it plays right into PADD but uses it rather than letting it control you.
    I'll get a rota drawn up of things to do, this might just work!
