an my overvoltage protection circuit connect in this way?
the voltage input, 'V in' go through the voltage regulator, which are Zener diode D7 series with Resistor R2 showing in the attachment. Zener diode D8 connect parallel with D7 and act as the protection or prevent of reverse polarity of voltage and current going through output.
to consider the overvoltage, i add the thyristor parallel with D8, can it be connected in this way?
