Overloaded Sanwa PM3?
Discussion in 'General Electronics Chat' started by deyk, Jun 13, 2011.
  1. deyk
    Jun 13, 2011
    Hi.. Does anyone know how to repair Sanwa PM3? I just used it to measure the voltage of mosquito racket zapper and the display went blank. The multimeter max rating is 500volts. Is the mosquito racket zapper voltage higher than 500volts?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The "mosquito zapper racket" could have several thousand volts on the grid.
    You should not have used the meter to try to measure the voltage.
    You may have blown the meters' internal fuse, or simply fried the meter. If the fuse inside the meter is OK, throw the meter in the trash and buy another.
  3. deyk
    Jun 13, 2011
    The thing is the multimeter doesn't have fuse inside.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Then throw the meter away, and buy another one. I suggest getting a Fluke. They are not cheap, but one good Fluke meter will last you for a very long, long time.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    A good Fluke also has protection circuits so it won't disintegrate when you try to use it outside its limits. I've had mine for 32 years and never had to repair anything but the fuses.
  6. debe
    Sep 21, 2010
    955
    185
    The packaging on the mosquito zapper raquet says 2700Volts, wonder how the Fluke would handle that?
  7. KJ6EAD
    Apr 30, 2011
    1,426
    364
  8. #12
    Nov 30, 2010
    16,704
    7,354
    Like I said...fuses!
