overload circuit
Discussion in 'The Projects Forum' started by jblueink, Jan 28, 2009.
  1. jblueink
    May 27, 2008
    24
    hi there,can any body help with an overload circuit.am designing a square wave inverter and i want to add an overload circuit so i can be able to detect when the system is overloaded.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You could try to measure the current in the power transistors.
    That should give an idea about the power used.
    Greetings,
    Bertus
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or you can just add a circuit breaker or fuse to open the circuit on overload.
  4. jblueink
    May 27, 2008
    24
    thanks for your advice.
  5. DickCappels
    Aug 21, 2008
    2,758
    667
    So...what's your circuit?
    The circuit topology is important in determining the best short circuit protection scheme.
