overflow condition when adding two binary numbers
Discussion in 'Math' started by PG1995, Oct 18, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    Please have a look on the attachment. You can find my question there. Thanks for the help.
    Regards
    PG
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    You check the sign of the result. When adding two numbers with the same sign, the result must also have the same sign. If it doesn't, then overflow has occured.
    PG1995 likes this.
