Overcurrent Protector?
arjayfall
Joined Dec 29, 2013
Hello guys,
So I'm currently working on a fingerprint-security system on a motorcycle. The security system is perfectly working. But my problem is the power source. In order to power-up my system properly, i need to supply it with another battery source because if i use the motorcycle's battery my security system would reset when starting up the motorcycle. My mentors really challenges me to device a powersupply circuit that would only use the motorcycle's battery and would not reset my system during ignition..
I'm hoping for suggestions for a power supply circuit that would conquer this problem..
Thanks!! ;) God Bless
inwo
Joined Nov 7, 2013
2,419
Feed from a diode into appropriate capacitor?
Without another battery, what is there?
A flywheel? :)
ps.
What's with the title?
34,411
Tap into the ignition power, since that voltage isn't interrupted when starting. Then add a series diode feeding a large capacitor to maintain the system voltage due to the battery voltage drop from the starter current.
