over voltage protection help
Discussion in 'The Projects Forum' started by hanibal517, May 18, 2009.
  1. hanibal517
    May 23, 2008
    hi, i am a student of diploma, currently donig a project on how to protect instrument from overvoltage ...
    i am currently using an isolating transformer 400/230V 400Va
    but each time i switch on the power i noticed that the secondary voltage is 240V, how can i correct this ?
  2. heavyarms666
    Member
    May 16, 2009
    20
    its maybe the current rating, do you checked it?
  3. mik3
    Feb 4, 2008
    4,846
    63
    If you have the primary connected between two phases then you will have 240V on the secondary because the voltage between two phases is 415V and not 400V.
  4. DonQ
    May 6, 2009
    320
    11
    Yeah, your only options are to either change your input voltage, or change your transformer.
    Some transformers, maybe not a small one like you are using, have different taps available on the windings to allow adjustments for slightly different input voltages.
