I will probably not understand the answer, but here goes.
I am wiring a LED light to my motorcycle to alert me when my radar detector goes off. Using the headphone output to trigger a solid state relay (Magnecraft 70S2-04-B-03-V) to control the LED.
I am getting the 12V from a relay wired direct to the battery.
When I put it all together on the bench and tested it using my car batery charger as a power source it worked perfect. The LED flashed in sync with the sounds the radar dectector would make if the earphone jack was not being used.
When I wired it to the bike and activated the radar dectector the LED came on and stayed on as if the relay was not resetting.
Any ideas for an electronics idiot?
