Just as you had predicted!Looks right. It is two halves (mirror image) of a cosine wave.
The angles at the pointed ends are both 90 degrees.
Ah, you're right. I have a cell that is for the radius of the tube and I put 1.75" when I should have put half that. Of course, I could have (should have) just used 1.00" because it is trivial to scale it up and down. I was even thinking of putting multiple patterns inside each other for different ratios of the two diameters. Then you could see it go from real close to a circle to this shape. I may yet do that.Yes, similar, but yours is better. Mine is attached to post #10.
ETA: I just looked at the scale on yours. If the scale is in inches, yours is twice as big as it should be, but the shape is correct.
I can remember giving almost a week's pay for a four-function calculator with a seven-segment LED display.I had to figure all that out with pencil and paper, when I started in the 50s.
What is a computer?
What is a computer?
That's pretty much what I did just now.Yes. Please do that. It would be interesting to see.
If you plot it in a CAD program you can actually get a scaled drawing. There are other software packages that produce accurately scaled drawings - for example some of the LaTeX packages, and these have inbuilt functions like sin and sqrt as well, and are free.I got curious as to how much effort it would actually take to do it with Excel. It actually turned out to be much easier than expected. Here's what it looks like:
Of course, the pixels are not exactly square, but you get he idea.
I had a similar experience my first year in college when I started using a calculator in virtually all courses. By the middle of the spring semester I found myself pulling out my calculator to add two simple (i.e., no carry) two-digit numbers. That was a wake-up call and I discovered that I actually had a bit of a hard time adding them in my head. From that day on I resort to a calculator only for "reasonable" problems. It's paid off nicely in keeping my mental and mechanical math skills in pretty good shape. My students are often amazed at how quickly I can do the arithmetic on the board, but unfortunately that says a lot more about their math skill than mine.I started using calculators in the late 70s, sure did spoil my "Head Math".
Got into computers as a career in part because of writing a short program for a professor that calculated grades at the end of the semester.I taught school for one year straight out of college. Without a calculator, averaging grades took me more time than grading the papers.
by Aaron Carman
by Jake Hertz
by Robert Keim
by Jake Hertz
