Output won't respond to button input (Microchip DV164132 evaluation board & PIC16LF1937)
Discussion in 'Embedded Systems and Microcontrollers' started by k1mzz, Jul 31, 2016.
  1. k1mzz
    Jul 31, 2016
    7
    I am new to PIC and C and have purchased a Microchip DV164132 evaluation kit (http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=dv164132). This is based on the PIC16LF1937 microcontroller.
    I am trying to get an output to respond to an input - when a button is pressed, I would like an LED to illuminate.
    To sum up the schematic: The switch is connected to RD2, which (from my interpretation) remains high unless the switch is pressed (where it goes low (GND) for the duration of the press).
    So what I want to do can be summed up as:
    do forever
    if RD2 = low
    RE0 -> 1
    else
    RE0 -> 0
    end
    So I have written the following:
    Code (C):
    1. #include <xc.h>
    2. // CONFIG1
    3. #pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
    4. #pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
    5. #pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
    6. #pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
    7. #pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
    8. #pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
    9. #pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
    10. #pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
    11. #pragma config IESO = ON        // Internal/External Switchover (Internal/External Switchover mode is enabled)
    12. #pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
    13.
    14. // CONFIG2
    15. #pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
    16. #pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
    17. #pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
    18. #pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
    19. #pragma config LVP = OFF        // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
    20.
    21. // #pragma config statements should precede project file includes.
    22. // Use project enums instead of #define for ON and OFF.
    23.
    24. void main(void) {
    25.     //Set direction of ports using the TRIS register
    26.     TRISDbits.TRISD2=1;
    27.
    28.     //PORTE - all output
    29.     TRISE = 0b00000000;
    30.
    31.     //Set all bits on PORTE to 0
    32.     LATE = 0;
    33.
    34.
    35.     for(;;)
    36.     {
    37.         PORTEbits.RE0 = !PORTDbits.RD2;
    38.     }
    39.     return;
    40. }
    It compiles correctly, but the LED connected to RE0 remains illuminated irrespective of whether the button on RD2 is pressed or not.
    What am I doing wrong?
    Many thanks,
    Kim
    Mod edit: code tags
  2. k1mzz
    Jul 31, 2016
    7
    Also, to add, I'm not concerned about debounce at the moment - I just want to see the button on an input do something!
  3. k1mzz
    Jul 31, 2016
    7
    Apologies for not using the code tag - forgot to save the edit within 10 minutes!
  4. NorthGuy
    Jun 28, 2014
    611
    121
    You need to initialize your pins:
    Code (C):
    1. // make D2 digital input
    2. TRISDbits.TRISD2 = 1;
    3. ANSELDbits.ANSD2 = 0;
    4.
    5. // make E0 an output
    6. TRISEbits.TRISE0 = 0;
  5. k1mzz
    Jul 31, 2016
    7
    Thanks for that; the line ANSELDbits.ANSD2 = 0 sorted this.
    Why would this be needed? I thought all inputs were digital by default?
    Cheers :)
  6. NorthGuy
    Jun 28, 2014
    611
    121
    Usually not. This is because digital inputs waste power if they're not connected to anything.
  7. dannyf
    Sep 13, 2015
    2,196
    417
    Reading the gpio section of the data sheet will answer that question.
    k1mzz likes this.
