Output voltage waveforms of diode circuits
Discussion in 'Homework Help' started by boks, Oct 28, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
  2. mik3
    Feb 4, 2008
    4,846
    63
    Is Vi an AC voltage source?
    Do you assume that the diodes are ideal?
  3. boks
    Oct 10, 2008
    218
    Yes, the diodes are ideal. Their turn on voltage is 0.7 V. Vi = Vosin(wt)=5sin(wt)
    I assume circuit A will clamp voltages lower than - 0.7 V, while for circuit B the output will be clamped to +- 0.7 V? No idea when it comes to C though.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Circuit A will clip voltages greater than 0.7 volts
    Circuit B will clip voltages greater than 0.7V and less than -0.7V
    Circuit C will clip voltages greater than 2.7V and less than -2.7V
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Circuit C will clip voltages greater than 2.7V and less than 1.3V.
    This was homework. We should have asked to see the OP's answers first.
  6. mik3
    Feb 4, 2008
    4,846
    63
    Thanks RonH for the correction, i was not very careful.
  7. boks
    Oct 10, 2008
    218
    You mean greater than 2.7V and less than -1.3V?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, he meant just what he posted. You might get some useful knowledge by looking into the conduction characteristic of a diode.
