Output stages
Discussion in 'General Electronics Chat' started by xkris, Mar 13, 2011.
  1. xkris
    Mar 13, 2011
    Hi all,
    I have a question concerning these two buffer ICs.
    SN74LVC07A and SN74LV244A
    My guess is for the first chip I have to provide external pull up resistors while for the second one external pull ups are not required. I suppose the output stages on the SN74LV244A are CMOS although the datasheet doesn't explicitly say so
    Can anyone help please?
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Welcome to AAC.
    Concerning your question, You are correct.
    xkris likes this.
  3. xkris
    Mar 13, 2011
    Ok, thanks a lot
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Both devices are CMOS technology throughout.
  5. kingdano
    Member
    Apr 14, 2010
    377
    19
    you are correct
    you can use the open-drain IC to interface between a 3.3V block of logic and a 5V block of logic quite nicely.
  6. xkris
    Mar 13, 2011
    By CMOS I actually meant a complementary transistor pair.
    That's what I intend to use them for (is this correct english... :confused:)
    The second one (SN74LV244A) does the same job, only faster and without the need for additional resistors.
  7. kingdano
    Member
    Apr 14, 2010
    377
    19
    well depending on the particular logic family you are interfacing to a 3.3V signal may not have the correct noise margins for reliable interfacing tp a 5V system. the device without the open drain will swing all signals to within its Vcc rail and ground.
    the use of the open drain is to "pull-up" the signals on the "secondary" side of the buffers to the higher (+5V) voltage level so that you get full 0V to 5V swings from your 0V to 3.3V swings on the "primary" side of the buffer. this can work the other way as well, where you pull up the "secondary" signals to +3.3V and have the inputs driven by 5V logic.
    i hope that better explains the use.
    -Dan
