Hi guys!
I'm a bit confused. I have a question regarding the effective dc output resistance of dc power supplies. For a "good" power supply, should this internal resistance be large or small?
Well, I used to think that good power supplies should have a small internal resistance, so they would maintain a constant voltage until exhausted before droping to 0. However, I did an experiment and found that regulated power supplies (which give a more steady outoput with less ripples), tend to have a higher output resistance than the unregulated power supplies. So does this mean the dc power supplies with larger resistance are more desirable?
I greatly appreciate it if anyone could confirm this, and also explain briefly why higher internal resistance reduces the output ripples.
