Just got a brand new toroidal transformer rated at 230V primary 24V secondary @ 2.5V and before hooking it up to 240V (UK) supply decided to test it with a low voltage AC wallwart supply. There was 11.08 VAC on the primary and I measured 1.336 VAC on the secondary (i.e the primary seems to represent about 15% of the input).
So, my question is whether testing at low voltage like this is representative of the percentage voltage drop when running from the specified mains voltage. That would be a bit worrying as 15% of the input voltage (240 VAC) would result in an output on the primary of circa 36 VAC rather than the rated 24 VAC.
I'm hopeful that someone can reassure me that low voltage tests cannot be translated to the outcome at full mains voltage. Thanks for reading.
