output of simple logic circuit
Discussion in 'Homework Help' started by sagar474, Jul 22, 2010.
  1. sagar474
    Jul 22, 2010
    16
    what is the out put Y of this logic circuit?
    those are nand and nor gates
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you tried to determine the states of A & B that will produce Y? After that, it's simple to work in the C input. It's helpful if you label the gates, too (U1, U2, etc.).
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Start from the list with all possible combinations of A, B and C. Then work your way from the left to the right of the circuit. For given A and B find the output of the first gate. Then use it along with B to find the output of the second gate and so on.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Basically what has been said previous. Just make and use a truth table. If you need visual assistance draw the circuit 8 times, and use a red or green magic marker to record the output of each gate to fill the truth table.
  5. raihanbd89
    Jul 30, 2010
    Wht r d input of d right most nand and left most nor gate?? Actually i can't figure it out.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    See post #3. Make a truth table:
    A..B..C..Y
    0..0..0..?
    1..0..0..?
    etc.
