I could use some help on how best to approach a problem like this. The diode is ideal. My attempt so far is:
1. Before the pulse the diode is off because of the 10 volt source. Then its just a series resistor and capacitor. At steady state all ten volts are across the capacitor and current is zero.
2.So after the pulse the same thing should happen with v2 going to 10 volts.
3. During the pulse there's a new three volts on one side of the diode. But I don't see how that is enough to turn the diode on. If the diode doesn't turn on the circuit can't change.
I'm not really sure where to go from here. Any help would be greatly appreciated.
