Output of a gate with load attached
Discussion in 'General Electronics Chat' started by hinduheads, Jan 9, 2016.
  1. hinduheads
    Jan 8, 2016
    Suppose I design an OR gate such that the output voltage is high when either of the input voltage is high. So far so good. But if I add a load at the output, the output voltage can change and can drop to a level of logic zero. How do we get around this problem?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    What kind of gate do you use?
    Is it CMOS or TTL?
    Cmos can deliver 2 mA at most.
    TTL can deliver 20 mA at most.
    Read the datasheet of the gat for the exact values.
    Bertus
  3. GopherT
    Nov 23, 2012
    6,315
    4,038
    @hinduheads
    You need to add a "buffer" to the OR gate's output. That will allow the OR gate to function correctly (and not exceed it's designed current limit and, make sure that the load is powered correctly.
    You can add a "logic level MOSFET", a transistor that is switched by voltage applied to the gate ( no continuous current flow to activate the switch) and the source-to-drain current can be 10s to 100 amps, depending on the MOSFET you select.
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    What is the value of this "load"?
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,297
    For any circuit, not just logic devices, if the current required by the load is greater than what can be sunk/sourced by the device, you heed a bigger output stage. For logic circuits this frequently is an external switching transistor that can pull the load up or down depending on the parts.
    ak
  6. hp1729
    Nov 23, 2015
    2,098
    232
    Higher capability driver.
