output level in 433mhz rf receiver
Discussion in 'General Electronics Chat' started by GoswamiG, Dec 20, 2015.
  1. GoswamiG
    Aug 26, 2015
    5
    Hello all,
    I need some urgent help in my project.
    i am making a rf comm project. I am able to get the output at my recevier but output is very low.
    around 2 volt
    I am using uart rxd to recieve the data, but it is not generating any interrupts. That is probably because of low voltage. I have checked loop back form my code. It is working fine.
    I have a combination of ws-rx-07(though i dnt find any datasheet) as a recevier and auk r433a as transmitters and atmega328p.
    Kindly help where i am doing mistake, attached my oscilloscope out yellow signal is input.
    how i can increase the voltage level. If any one have any reference circuit or datasheet of the above recevier please share.
    Rgds
    SG
  2. nerdegutta
    Dec 15, 2009
    2,569
    806
    In order to get the right help, it would be nice to upload your schematics/ high res pictures, of both the transmitter and receiver. Your code is also important.
    Why?
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    You gave us an image of some squiggly lines with no explanation, but kept your datasheets a secret. You probably will get similar answers.
    ak
  4. Veracohr
    Jan 3, 2011
    559
    77
    If you need to increase the voltage level, amplify it.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It is unlikely that you need more voltage. More likely is that interrupts are not enabled. It takes more than one statement to do this in an ATmega328.
  6. GoswamiG
    Aug 26, 2015
    5
    Thanks for replying and sorry for delayed response. Please find the attached code circuit diagram and oscilloscope explanation
    Also i have noticed when the output of receivier is not connected to controller out is coming as expected i.e 5 v.
    I have read somewhere concept of overloading...
    BTW same circuit working fine in loop back and with max 232
