The output resistance of an opamp is about 50 ohms to 200 ohms.
But since it is almost always used with negative feedback then its output impedance at low frequencies is very close to zero ohms.
If a load tries to change the output voltage then the negative feedback will cause the output voltage to cancel the change by the load.
