Its just a comparator circuit using an op-amp, i guessGreetings!
A circuit with 2 inputs and 2 outputs. Inputs are (-), but with impendances, R1 and R2 (0 - 1000 Ohms). When R1 > R2, then +12V goes to Output1, and when R1<R2 then +12V goes to Output2. Circuit works on 12V (in car)
Or it could be a comparator circuit using a comparator.Its just a comparator circuit using an op-amp, i guess
yes you are rightWhat are the names of components U1 LM111, and Q1 2N222? Is the first comparator, and the second transistor?
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Aaron Carman
