Hello everyone
I have a Tektronix TDS 210 oscilloscope and I'm supposed to measure the output current of several types of ballasts. So far I found out that I need to use a shunt ressistor because I don't have a current probe, and that I have to use both channels considering I dont have a differential input. As a shunt I tried to use a 3,7 m, 0,25 mm^2 copper wire (if I calculated corectly it has about 1.4 ohms resistance). I connected this wire in series with the lamp (ballast). The lamp is connected directly on 231 V. I used the math function Ch1-Ch2 (one probe on each end of the 0,25 mm^2 wire), and what I got was a normal sinusoidal wave. This can't be correct! No matter how high quality the ballast is, it has to change the shape of the current signal. It seems to me I'm getting the input voltage from the socket.I don't really care about the amplitude of the current, only the shape of the signal so the shunt doesn't have to be precise. Could someone suggest what am I doing wrong please?
I' ve posted this to other forums as well and any help is appreciated.
