I need a 24V power supply for an LED lighting project that will all be outdoors. I was thinking about buying this power supply:
http://www.allelectronics.com/make-a-store/item/PS-24150/24-VDC-6.5A-150W-POWER-SUPPLY/1.html
Then installing it in an outdoor electrical enclsoure (the grey box with the flip up front panel). I would knock out all the holes in the bottom for some airflow and maybe put in a fan. It should last for 5 years. Will the moisture effect this switching power supply circuit in a bad way? How do you handle heat dissipation in an outdoor environment?
Thanks.
Thanks.
