oscope bandwidth
concievo
Joined Nov 13, 2010
5
In order to measure transceiver circuits up to 50MHz , what is the minium bandwidth of an oscope needed.
I have read that you should get one that has a BW of five times the frequency of the circuit under test. If that is so then it's way out of my budget envelope,but a 50 MHz one is not.
mik3
Joined Feb 4, 2008
4,843
You have read well. To be able to view a signal on the scope accurately you need a scope with at least 5 times the measured signal bandwidth. If you use a 50MHz scope to measure a 50MHz signal, you will see its amplitude/sqrt(2) on the scope and it will be phase shifted too.
Rbeckett
Joined Sep 3, 2010
208
Bertus, your depth of knowledge and ability to link valuable info never ceases to amaze me. I can only aspire to one day have the depth you exhibit on a daily basis. Thanks!!!
Bob
concievo
Joined Nov 13, 2010
5
Thanks for the info gentlemen, but alas I am still confused (an old dog finding it hard to learn new tricks).
I am finding differing opinions on the subject i.e.-
5-10 times the f under test for Digital circuits.
2-3 times for Analog.
As I have bought a Rigol DS1052E (50 MHz) for $400 new, and I would dearly love it if 2 times for Analog was correct. I will be building QRP gear up to 17M from Ham produced kits. Iam a new Ham,but not entirely new to electronics -serving in the USAF as a Radio/and Nav Aids Tech way back when solid state was just taking over (57-66).
The above scope can be hacked to 100 MHz if you get the one with the old Firmware,saving $300. See EVV blog site episode #70. Please delete that if not acceptable.
mik3
Joined Feb 4, 2008
4,843
Digital signals need more bandwidth in order to capture their fast rising/falling edges accurately. Analog signals have slower rising/falling times and thus they need less bandwidth to be captured with acceptable accuracy.
