Oscilloscopes This one good?
Discussion in 'Electronics Resources' started by Dominick, Feb 11, 2009.
  1. Dominick
    Dec 6, 2008
    28
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would be unhappy with the 9 bit resolution - that's only 1 part in 512. No problem for PWM waveforms, but might be coarse for analog waveforms.
  3. Dominick
    Dec 6, 2008
    28
    oooo Ok well this is probably not feasible But might I be able to get something to do what I need for about that price?
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Have you considered one of the very inexpensive Velleman scopes, if all you are doing is PWM for motors and the like (i.e., < 1 MHz)? That's what I got and it worked fine for that purpose as well as for reading and setting keys codes etc. I suspect they are available used for less than $50 or so for the 5 MHz version.
    They are also portable and can be used for trouble shooting automotive and field issues.
    John
