Oscilloscope
Discussion in 'Homework Help' started by akifnadeem, Dec 23, 2010.
  1. akifnadeem
    Apr 9, 2010
    15
    when we add two signals in oscilloscope, we get a resultant waveform. Both two signals have different TIME/DIV & VOLTS/DIV settings. Problem is how we can measure the voltage of the resultant waveform, i mean with respect to CH1 or CH2's Knob setting???
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    You can best add the signals when the two channels are at the same setting.
    Attached I have a PDF on the use of oscilloscopes.
    Bertus
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Usually, digital oscilloscopes use common settings when adding waveforms. I 'm not that old school to know how they did it whith the analog ones. I 've used them only once or twice.
