oscilloscope to measure RPM?
Discussion in 'The Projects Forum' started by 03GTS, Jun 2, 2009.
  1. 03GTS
    Jan 5, 2007
    12
  2. mik3
    Feb 4, 2008
    4,846
    63
    Does it output DC or AC voltage?
  3. Externet
    Nov 29, 2005
    780
    58
    With your generator running at a somewhat steady speed, connect the oscilloscope to its output and if there is any repetitive waveform or spike, you can discern its period on the oscilloscope.
    Turns per second = frequency = 1 / period. If you want turns per minute instead of per second, multiply by 60.
    Miguel
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    If you have a photocell or photoresistor you could aim at the blades (assuming you have some daylight) you might get enough of a reflection to see on a scope.
  5. studiot
    Nov 9, 2007
    5,005
    515
    Yes except that you may have to divide by the number of poles on the generator.
  6. 03GTS
    Jan 5, 2007
    12
    looks ac just by hooking up my multimeter to it. it reads 0 volts on DC. I am able to get a reading on AC
    will try this weekend
    i dont. but will remember this for future reference thank you
    noted. thanks
    will report back with what i find this weekend :)
  7. studiot
    Nov 9, 2007
    5,005
    515
    Unless your multimeter is very sophisticated it reads average on AC. This can be seriously misleading on waveforms very different from sinusoids.
  8. mik3
    Feb 4, 2008
    4,846
    63
    If it is AC, use the scope to measure its frequency and then calculate the angular velocity by using:
    ω=2*pi*f
    If you want rpm=ω*60/2pi
