i'm interestend in this pc based oscilloscope but i'm not sure if this one is rigth for me.
can u tell me the maximun voltage signal i can measure with this scope?
the maximun bandwidth i can measure?
PC Oscilloscope Specifications
General specifications
Input Channels: 7 internal, 2 external
Sampling Rate: 10 to 15,000 per second (PC dependent)
Overload protection: +30 volts
Digital Outputs: 1 TTL (With 1-3 k Ohm Impedance) 1 LED
Dimensions: 50 X 70 x 20 mm
Output Connector: 25 way male D-type to PC parallel port
Supplied Software: Picoscope, PicoLog, and additional software drivers
Internal Sensor Specifications
Channel Range Resolution Accuracy
Sound Waveform + 100 0.02 not calibrated
Sound Level 55 to 100 dBa 1dBa 5dBa
Voltage 0 to 5 volts 5 mV 3% of FSD
Resistance 0 to 1 MOhm 0.1 kOhm(at 10kOHM) 2% (at 100kOhm)
Temperature 0 to 70°C 0.1°C (at 25°C) 2°C (at 25°C)
Light 0 to 100 0.1 not calibrated
External Sensor Specifications
pH 0 to 14 0.02 pH calibrated dependent
Temperature -10 to 105°C 0.1°C (at 25°) 0.3°C (at 25°C)
Humidity 20 to 90%RH(N.C.) 0.2% RH + 10%
Reed Switch open/closed
thanks for your help
