Oscilloscope Repair
Discussion in 'General Electronics Chat' started by nDever, Jun 24, 2014.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey Guys,
    I've got an HP 1741A 100MHz dual channel analog storage scope, and it was working relatively well until one day when I went to turn it on and there was no signal coming up. It takes a few moments to warm up anyway, but this was longer than usual. I popped the top to see if I could find anything, and I found this IC-like connector part missing a pin. It looks like some type of ribbon connector. Sorry for the lack of focus in the photos.
    Anyone have any ideas or know where I can possibly get a replacement part? It's a good scope and I would like to save it if possible...
    The persistence button is also loose, but I think that's just a fastener problem. Shouldn't be too much trouble.
  2. dougc314
    Member
    Dec 20, 2013
    38
    11
    If your scope was working there is no reason to suspect that you just lost a pin. As for spare parts you'll need a doner scope.
    Do you see a trace?
    If you adjust y position and x position to max and min, can you see anything? Is there a beam finder button? if so push it and see if you can get a dot.
    Is there any indication of triggering? - Try Auto or line
    What can happen to cause loss of trace
    High voltage supply for CRT fails
    Driver in X or Y deflection fails, causing trace to be off screen
    CRT heater failure.
    Sweep circuit fails (still get a dot though, usually)
    Great news - Agilent has a PDF of the service manual
    http://cp.literature.agilent.com/litweb/pdf/01741-90911.pdf
  3. ErnieM
    Apr 24, 2011
    7,437
    1,626
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I have an HP1741A myself that I repaired (A capacitor exploded and corroded a large section of the timebase board), and I believe that ribbon connector/DIP socket is normal. It is most likely not the problem.
    Was the scope acting strange before it stopped working? What exactly is it doing now? Are you sure the trace isn't simply off the screen? (Adjust both the vertical and horizontal position to see if you can locate it). Also try the beam finder.
    A video would be extremely useful here.
    Regards,
    Matt
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    The service manual is readily downloadable for free. Just Google the model number.
  6. nDever
    Jan 13, 2011
    154
    Thanks for the insight, guys. I'm not at the workbench at the moment. I'll test it asap.
    @DerStrom8
    I don't recall it acting strangely before it stopped working.
  7. MrChips
    Oct 2, 2009
    12,636
    3,454
    Get set for some fun trouble shooting.
    You will need some tools:
    Service Manual, i.e. circuit diagrams
    DMM
    camera to post pictures
    Do you have a working scope?:p
  8. nDever
    Jan 13, 2011
    154
    Eh...no. :rolleyes:
  9. nDever
    Jan 13, 2011
    154
    Hey Guys,
    I did bit of digging yesterday and it turned out that the DIP header was the problem! I also re-soldered some cold joints on some of the control pots. A big thanks to all.
  10. MrChips
    Oct 2, 2009
    12,636
    3,454
    Can you elaborate on what you did to the DIP header in order to fix the problem?
  11. nDever
    Jan 13, 2011
    154
    I was afraid of that... :rolleyes:
    I soldered a piece of 22 AWG to the broken pin. A bit unorthodox I think.
  12. MrChips
    Oct 2, 2009
    12,636
    3,454
    Next question. How did it become broken in the first place?
  13. nDever
    Jan 13, 2011
    154
    Fine, I admit :(. When I went to look inside the first time, I may have pulled too hard on it.
  14. MrChips
    Oct 2, 2009
    12,636
    3,454
    Thanks for owning up. DIP pins don't just fall apart on their own accord.
  15. nDever
    Jan 13, 2011
    154
    OK guys,
    I've got another problem and It's not my fault this time; I suspect a bad IC. The scope seems to be stuck in Store Mode. Does anyone know where I can find the schematic for this scope (if it's available)?
