Oscilloscope questions ?
Discussion in 'General Electronics Chat' started by curry87, Aug 24, 2011.
  1. curry87
    May 30, 2010
    101
    When does a hobbyist need the use of a oscilloscope please give examples?
    Using a analog oscilloscope how do you analyze a audio amplifier to observe the amplification of a input signal to calculate a rough voltage level if the input signal from a mic is not constantly being generated ?
  2. JDT
    Feb 12, 2009
    658
    85
    Very useful for checking the gain of an audio amplifier. As well other things.
    In your case, you need an audio signal generator as well. If you want to test the microphone connect the signal generator to an audio amplifier and place the microphone in front of the speaker. Otherwise connect the signal generator to the microphone input. Or whistle very steadily and long!
    Connect your 'scope to the input. Record the signal amplitude.
    Connect your 'scope to the output. Record the signal amplidude.
    Do maths.
  3. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    It may be because I'm drunk but I don't get what you're asking.
    An o-scope allows you to see a waveform; it's frequency, it's shape, it's peak to peak voltage (calulated by the scale it's set to). All very useful stuff, I find that I do not need my oscilloscope much however it is immensely helpful when dealing with very low voltage signals, acctually it's just fun to watch the wavey waveforms sometimes :)
  4. praondevou
    Jul 9, 2011
    2,936
    489
    LOL.
    If you want to work seriously with electronics projects, you NEED an oscilloscope, better digital than analogue.
    It's the best way to analyze signals in your circuits, unless you work with almost static DC-circuits (where you could use a multimeter).
    You can make visible voltage peaks, current waveforms, measure and relate to each other a number of signals... all things that are impossible with a multimeter.
    There are several problems that can occur in electronic circuits you could only resolve by experience or an oscilloscope (and a little bit of experience);)
  5. HDAV
    Member
    Aug 21, 2011
    43
    I just got a STingray USB scope and I am struggling with it in my case its to analyse a circuit in "real time" where the times are smaller than a human can record a very fast data logger will do the same
