Oscilloscope Project
Discussion in 'The Projects Forum' started by saint_jay77, Oct 20, 2006.
  1. saint_jay77
    Oct 19, 2006
    26
    I am planning to build an oscilloscope project..
    I was wondering of someone could briefly outline a block diagram and also advice good method of approach for this project. Basically i need a guideline!! Also what is the max frequency i could run this scope at without worrying too much about RF coupling on PCB...
    thanks....
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I vote for 2MHz as the maximum frequency. I urge you not to even embark on this project unless you have a good understanding of power supplies, transformers, high voltage circuits, oscillators, trigger circuits, microcontrollers, and amplifiers.
    If you want to consider this a multi-year project then by all means pick one of the above topics and dig in. You need to start with something less ambitious, and you need to learn to crawl and walk before you try to run a marathon.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You can look at this for reference.
    http://www.bitscope.com/
    It's a large undertaking that will take a lot of persistence and learning.
  4. saint_jay77
    Oct 19, 2006
    26
    I didnt think it would be so difficult. thanks for the info and for your time reading the post. I took the project as a challenge aiming high and learning a little about projects.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, the project is kind of hairy for a first. There are a number of potentially lethal voltages that have to be present to make the CRT work.
  6. saint_jay77
    Oct 19, 2006
    26
    Well one could use a PC for all that good stuff. I am more interested in the data acquisation, interfacing with C or C++ software, Looking at signals on PC screen, setting auto ranging feature, and all these would be done on an old pentium computer that is dedicated to such purposes. Thats what i am interested in; A good hardware and software interface and presentation of data on the PC screen. That would not be that difficult would it??? Havent really looked into it too much so please let me know if i have missed or over looked some part of the Block.. thanks.
  7. beck
    Member
    Nov 27, 2006
    26
    this article has the detailed circuit with the c program.
    just buy the componets and connect as shown in the ckt.:D
    http://www.electronicsforu.com/elec...tslist.asp?id=284&title=PC-Based Oscilloscope
