Oscilloscope probes does it matter what the frequency is?
Discussion in 'General Electronics Chat' started by bance, Oct 25, 2012.
  1. bance
    Aug 11, 2012
    315
    34
    Hi guys,
    I bought an old Leader 20mhz analogue scope on E-Bay, it's 2 channel but only came with 1 probe. I was considering buying another probe so that I can use both channels. I see them for sale, often listed by frequency, does this affect the readings?
    I understand they have to have the correct impedance but frequency?
    Thanks for helping a 'noob'
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The probe to buy must fit the input impedance and capacitance.
    Some times there is given X MΩ / X pF.
    Bertus
  3. bance
    Aug 11, 2012
    315
    34
    Thanks Bertus,
    I had a feeling that the frequency quoted didn't matter since it's the scope that does the work and not the probe!
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    When the frequency range of the probe is equal or greater and the impedance is right, it should work.
    Bertus
  5. MrChips
    Oct 2, 2009
    12,652
    3,461
    Why spend extra money for a higher frequency probe when you don't need it?
    Here are a few things you should know about probes.
    Since your scope is 20MHz, which is relatively low by today's standard, maybe you don't even need a probe. A simple coax cable with a BNC connector on one end and alligator clips on the other will do fine for audio frequency testing and microcontroller debugging.
    If you are looking to purchase a proper probe, get one that is a 10x attenuation probe or one that has a switch selectable 1x and 10x.
    When I use a probe, I always use it on the 10x setting. This increases the input impedance of the measuring system from 1MΩ to 10MΩ and it extends the bandwidth.
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    The frequency rating of the probe tells you it's usable bandwidth, the higher the better. Obviously, if your scope is only 20 MHz, a probe with 100 MHz bandwidth is better than you need but no problem.
    There were a few super scopes like the TEK 7904A that had bandwidths of about 275 MHz so the probes had to be super wide band to not compromise the performance of the scope itself.
  8. ErnieM
    Apr 24, 2011
    7,443
    1,628
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    I bought two sets off ebay. They seem to work perfectly with my TEK465. The compensation adjusts properly and the square waves look sharp edged.
    They are cheap made in China, but they work.
  10. spinnaker
    Oct 29, 2009
    5,103
    1,193
    I have them too. They seem to fit my needs.
    But I think you did a little better on price.
