Correct. A stereo signal will look like a tangle of string always moving.Hi Audioguru, so does this mean that instead of a time-varying waveform, because now the x-axis is another input voltage source, the x-axis will be the peak to peak of that input voltage source. And the same for the y-axis?
Do you remember the max/min voltages you used for that?The Z (intensity) was modulated by the volume level of the music.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
