Oscilloscope & Function Generator
Discussion in 'General Electronics Chat' started by paul_alan, Nov 27, 2011.
  1. paul_alan
    Nov 5, 2011
    43
    What would happen to the output of a function generator if you connected a 10Ω load to the output terminals? (Assuming you had it set up simply with a 1kHz output from the function generator showing a 2V p-p waveform on the oscilloscope).
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It depends on the function generator.
    You may very well burn up the output. 10 Ohms would be a very heavy load. I would use some sort of buffer/driver between the two.
  3. saturation
    Member
    Dec 21, 2008
    22
    Most FG are typically 50 ohms resistance in series with the load. You likely get 0.33Vpp.
