Oscilloscope ext. Z input , TTL output, Amplifier Output
Discussion in 'General Electronics Chat' started by watsongrey, Nov 1, 2014.
  1. watsongrey
    Oct 31, 2014
    94
    On some tektronixs Oscilloscopes there is BNC jacks on the back of the Oscopes.
    What is the Ext Z input used for?
    There is also TTL output and Ch1 or Ch2 amplifier output, but what would I use them for?
  2. RichardO
    May 4, 2013
    1,335
    429
    What model 'scope do you have interest in? The signals on these connectors are not normally used.
    The Z input modulates the brightness of the waveform on the CRT. How this works varies a little between 'scope models. You would use this input if you were supplying your own X-Y inputs to the 'scope and needed to blank the beam when the X and Y positions are not valid.
    I am guessing that the TTL signal you are referring to is the sweep blanking signal. The blanking signal is active during the visible portion of the waveform. The blanking signal can be used to synchronize other test equipment to the signal displayed on the CRT.
    The Channel 1 and Channel 2 are the voltages you see on the CRT. You might use these outputs if you wanted do some kind of signal processing on the waveform you are viewing.
    I hope that these quick explanations help.
  3. watsongrey
    Oct 31, 2014
    94
    I'm using a Tektronix 2445 , 2246, 2245
    What would I use as a Signal Process or what do you mean?
    For a phase shift measurement?
    Why would you want the scope to blank the beam with X and Y are not valid?
    So I can take the TTL output of the Oscope and plug it into an input or the test equipment needs a blanking signal input?
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    My replies are in blue. As noted the applications for using these ports are few but are available in case you do have an application.
  6. atferrari
    Jan 6, 2004
    2,663
    783
    As requested already, better you say what model you have in mind.
  7. watsongrey
    Oct 31, 2014
    94
    Tektronix models 2246 , 2445
    If you wanted to do something else with the same signal that's been amplified by the scope's input amplifier
    Can you please give some examples of using the ch1 BNC output jack?
    Yes I know it amplifies the input signal through the Oscopes ch1 amplifier, but where would i send it to?
    Yes, for example if you want to synchronize some measurements with the observed sweep.
    So the test equipment would have to have a Blanking input to do this?
    But what test equipment would you want to synchronize can you think of?
    The TTL output on the Oscope, is outputting a sync signal from the Oscopes beaming circuit?
    The Z input can also be used to modulate the intensity of the beam such as using it to display
    So you mostly use a Logic signal or a Data signal as a source to the Z input?
    A Tech is looking for the Dot intensity blinking or not?
  8. Lundwall_Paul
    Oct 18, 2011
    222
    19
    The operating manual is attached.
  9. watsongrey
    Oct 31, 2014
    94
    The Tektronix 2445 has rear BNC jacks , GateA output and GateB output, what are they used for and how would you use them?
    Some Tektonix Z axis inputs are Positive going and others are Negative going , but they are TTL inputs so it's ment to take a logic signal high and low , ones and zeros
